Results 1 to 5 of 5
Thread: Puma & Procomm
    Nov 2006
    mexico
    Puma & Procomm
    how can I load a program to a PUMA using a serial cable and Symantec PROCOMM??
    does any one know what is the correct configuration???
    Sep 2006
    Finland
    Dont know procomm, but at least check:
    baud rate (4800 is ok)
    databits: 7
    paritety: even
    stop bits: 2
    RS cable should be cross-connect
    Setting should be same on both side (NC/PC).
    If problems please check www.cadem.com
    There you can find setting & cable instructions
    There is also a free program for data transfer, it's good.
    Transferring:
    In NC type "O2342" <read> <execute> or just <INPUT> (which Fanuc do you have??)
    Then send datafile from computer.
    Sep 2005
    Daewoo puma
    to connect with rs232 and procomm must have io channel set at 4 also on cnc.
    Registered dcoupar's Avatar
    Mar 2003
    I/O Channel 4?
    I may be wrong, but I think I/O channel 4 is for the PCMCIA card.
    *Registered User*
    Nov 2005
    Quote Originally Posted by dcoupar View Post
    Yes Channel 4 is for the card, use channel 1 2 or 3 just make sure whatever one you use has the correct settings. stop bits ASCII and Baud rate
    Bluesman
  • Posting Permissions
