| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
I've got a Puma 8S. I have production jobs for a 14 X 2.0 metric thread on 304 SS. I'm single pointing ID threads 1.75 inch deep. I have lots of chatter and am breaking inserts every 3 to 4 parts. Using a Horn brand carbide bar. What's the deal? Phoodieman |
| I was @ 267 RPM. .0784something for the tpi of course. I called the dealer and he recommended 1900 rpm with 25 passes. No spring passes. Chatter was a lot worse. It has to be in the setup. I swept the threading bar and I have avout 5 thou runout. It's a slant bed and the tool is running parallel to that so whats up. phoodieman |
| I changed over to a lay down 3 corner bar insert. I'm grinding clearance on the back side of the tip. It's a two inch deep ID thread. I tried several different settings in Master Cam. Offset left and right... cutting in the center...taking a lot of passes (32). Taking 8 passes. Spring passes, no spring passes. .001 thou last cut. Mind you this is 304 SS ID and I'm getting a lot of shavings packing up in the back. I've got .200 in the back of the hole, so the shavings pack up in there. I want try threading from ID out, but I would have to buy a new toolbar and inserts. I don't want a left handed thread. Lot of chatter and I'm getting pissed. I sweep the bar at X zero from the chuck. The holders are a little worn, but I'm within about two thou of center. It's a slant bed and as far as I know the insert should be parallel to the bed. I'm set up turret up so the bar is upside down. Phoodieman |
| I was cutting at 247 RPM. I called the manufacturer and they suggested 1900 RPM. I laughed out loud over the phone. I tried it anyway and it chattered like a mofo. I'll hit it again tomorrow and see what I can do. Phoodieman |
#12
| The tool's not upside down. (Well if you look at it it's turned away from you in the cutting position) It's turret up configured, so to answer your question the spindle is turning the right way. I started putting a lot more passes in and the chipping of the insert went away. When I went down to 150 RPM the chatter completely went away. In the part I'm making now small chatter is not an issue, so I sped it up to about 400 RPM to get the part out the door. The thread is a 14 X 2.0 metric. It's a long throw. 2 inches in a thru hole and the other part is 1.650 in a lind hole. Time is always an issue to the bottom line and if I get that part again, I need to tweak to get the cycle time down. phoodieman |
