The machine ran fine yesterday, this morning the control wont turn on, I have power to the drives but nothing anywhere else. Any ideas?
thanks
Usually this is a blown fuse on the control that prevents the nc from powering up, the fuse in question is usually behind the display, you can replace it and it should power up unless there is a short circuit then it will probably blow again, hope this helps
