Results 1 to 10 of 10
Thread: Doosan 220 lynx issue...
    Apr 2012
    uk
    Hi guys and gals.....
    im new here so please be gentle with me....
    i have a problem with said machine, al funtions fine but when i rapid to from last cut into doing other cuts it sometimes touches the job before it gets to position....this sounds strange but it kinda ignoring its rapid to position in favour of trying to cut material....i overcome it using dwells but having spoken to an engineer he assured me its a parameter issue and its some sort of time saver.....
    well i dunno any other way to explain. hope thats enough to go on.
    thanks in advance
    May 2010
    Is this a G76 cycle?
    Registered dcoupar's Avatar
    Mar 2003
    It is a parameter issue. What model control is it? 0iTB, C or D or something else?
    IIRC, on the 0i's it's parameter 1601 bit 4 RTO.
    Apr 2012
    uk
    thanks guys....its not the g76 issue and it is a 220b lynx oi te
    is that how the parameter should look or will be at the moment???
    Thanks again
    Mar 2003
    Quote Originally Posted by enigma173 View Post
    Thanks again
    There is no 0iT-E.
    My guess is that 1601 bit 4 is set to 1 now. If you change that to 0, the problem you are experiencing should go away. This parameter is the same for 0iT-A to 0iT-D.
    Sep 2011
    UK
    Yes it's corner rounding caused by the servo not finishing it's last move before the control starts reading and performing the next line. I'll dig out the parameters you need to change tomorrow if you still need them. Tends to effect the smaller light weight Lynx more than the Puma's. Let me know if you still need them (not sure how old the post is)
    Apr 2012
    uk
    Thanks Shamus.....will be most helpful.
    Sep 2011
    UK
    I'm back in the shop tomorrow, I'll bring my notes home scan and email them over to you if you give me your email address. Your welcome to PM me if your not keen on having your email address on here.
    Apr 2012
    uk
    np its timnorton2000@yahoo.com thanks bud
    Sep 2006
    india
    use G09-exact stop
    or G61
    1. Need Help!- live tooling doosan lynx 200
      By Jeremy.davis58 in forum Daewoo/Doosan
      Last Post: 02-24-2012, 08:23 AM
    2. Doosan lynx 220 LC made in china?
      By philrace34 in forum Daewoo/Doosan
      Last Post: 12-31-2010, 08:49 AM
    3. Doosan Lynx 220 Gang Tool or Turret?
      By abhthree in forum Daewoo/Doosan
      Last Post: 10-22-2010, 09:56 AM
    4. Need Help!- Doosan Lynx 220
      By Schljuutene in forum Daewoo/Doosan
      Last Post: 02-12-2010, 12:44 AM
    5. Doosan Infracore Lynx 220LM
      By HelicopterJohn in forum Daewoo/Doosan
      Last Post: 08-02-2009, 06:44 PM
