Results 1 to 4 of 4
Thread: G76 Feed Limit
    Jul 2008
    G76 Feed Limit
    Fanuc Series O-T. I need a feed rate of 11.5 IPR. Seems like it will only give me 150 IPM
    Feb 2009
    You sure 11.5 IPR? Thats huge. It may do it at 1 or 2 rpm, but not at any real RPM.
    Mar 2004
    Tennessee
    The formula is: RPM * PITCH = <160 IPM
    May 2007
    If I did the math correctly 150 IPM and 11.5 IPR works out to 13 rpm. If I'm not mistaken, some lathes have a lower limit of 50 rpm. Of course, if your lathe is large enough to make a few turns at that pitch, then it probably can go that slow.
  1. Replies: 2
    Last Post: 05-19-2010, 07:59 PM
  2. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 05:14 AM
  3. SX3 CNC Limit Switches
    By Babba in forum Syil Products
    Last Post: 09-23-2007, 02:44 PM
  4. Limit Switches
    By Drakkn in forum DIY CNC Router Table Machines
    Last Post: 08-10-2007, 05:57 PM
  5. Limit switches...what do I need?
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 03-09-2005, 09:23 AM
