Results 1 to 1 of 1
Thread: 3016 DMV (2006) critical help needed
    Jun 2008
    Fried a motherboard (Fanuc 0i B) with a critical job running. All tools now trapped on carousel. I switched motherboard from identical machine, booted up fine but won't home. Appears that there is something different about the way the positions are stored. Anyway, over traveled on -X and hit limit switch (slow speed). The only way I can jog now is by continuously holding the blue alarm button in.
    It appears that I have to either sync the machine position with this motherboard (parameters?) and reset the limit switch (how?) or somehow get my tools out of the carousel and move the board and tools to the other machine. I can't rotate the carousel with out homing the machine which I can't do without changing stuff on the control (it appears). Can anyone helps...please???
    Ok, I have managed to remove all the tools while holding in the blue reset button, and have returned the board to the machine it was in. That machine now also has the problem of not knowing where it is. What the values in "machine" read (monitor) are not where it is. I am assuming there is a way to tell the control where the machine is table really is, no?
  1. DMV 3016 - Fanuc 0i-mc
    By daewooDmv3016 in forum Daewoo/Doosan
    Last Post: 01-11-2011, 02:25 PM
  2. MW Critical Error
    By Tavroch in forum EdgeCam
    Last Post: 02-11-2010, 05:13 AM
  3. How critical is resolver frequency matching?
    By cra1g3r in forum Servo Motors and Drives
    Last Post: 01-18-2010, 09:22 PM
  4. Replies: 1
    Last Post: 09-05-2008, 11:15 AM
  5. 5/8 Ballscrew Critical speed
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 02-13-2008, 07:06 AM
