Results 1 to 5 of 5
Thread: Puma 12L, al-17 on rear keypad
    Feb 2010
    This code has been coming for some time now, preventing a ready condition. The repair guy hasn't figured it out so to prevent the down time over waiting for it to warm up and run, we've been leaving the main power on. Well, over the holiday weekend we turned it off for the week it would be down.
    That was a mistake. 8 days on now and it wont accept the 4 button simultaneous push to reset it we've been doing.
    Anyone have a direction this al-17 points to that we can go? I was told its an unspecified code. Help?
    Jan 2006
    Are you referring to the spindle drive unit alarm AL-17? If so, AL-17 means problem with NVRAM(non-volatile memory) chip on the spindle board. Please contact fanuc america 18883268287 for a procedure on how to initialize it.
    Feb 2010
    I believe that's what it is. We reset the parameters in the back with instructions, again, and it's operational again.
    But, what would be continually causing the code to show on that display? Is it a certain chip or board that is the culprit? It shows every time main power is turned off and back on. Using the simultaneous 4 button push brings all "0"'s on the display and the lathe to a machine ready state. Loren
    Jan 2006
    Need to send you some info via private message. says you are not able to receive private messages. Please make necessary changes and I will send you more info.
    Feb 2010
    As far as I can tell the settings are to allow pm's, but I did just turn on email. Thanks for trying to help.
    1. Need A Quote- RFQ - Aluminium rear panels
      By ofreeborn in forum Employment Opportunity
      Last Post: 03-08-2011, 12:04 PM
    2. Cad drawing of rear end
      By R5P7Duster in forum General Metalwork Discussion
      Last Post: 02-18-2011, 12:47 AM
    3. Need Help!- Front & Rear Tools
      By M250cnc in forum LinuxCNC (formerly EMC2)
      Last Post: 07-07-2010, 04:06 AM
    4. Additional rear light
      By pit202 in forum Haas Mills
      Last Post: 06-18-2010, 01:28 PM
    5. Rear toolpost operations?
      By zephyr9900 in forum Mach Lathe
      Last Post: 10-12-2007, 05:00 PM
