Results 1 to 5 of 5
Thread: Fanuc oi-mc controller
    Registered inkdaddy66's Avatar
    Jun 2011
    Once I get my program into the controllers hard drive from our server. How do I pull the program up to read it,modify if needed?
    Tbolt meatclaws-talkatap
    ...Snitches get Stitches...
    Registered MysticMonkey's Avatar
    Mar 2009
    Quote Originally Posted by inkdaddy66 View Post
    most fanuc controls do not have 'Hard Drives'
    If the program has been transferred to the cnc correctly
    in EDIT or MEM mode
    press PROG
    type the program number e.g. O0001
    press cursor down then it will appear on the screen
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
    Jun 2011
    Ok. Maybe not a hard drive but there is on board memory. Once in edit mode I was able to pull the program from the server. Once on the controller memory I'm not able to visualize the program to be sure that I'm running the correct program or verify the code one more time before slapping cycle start. I guess my main question is how to see my post. I've done it in the past with no problems but Its slipped my mind,as I dont use this particular controller on a daily basis. My everyday driver is a 31i
    Registered dcoupar's Avatar
    Mar 2003
    When you say "pull the program from the server" are you doing this through RS232 or the Ethernet connection? What steps do you perform to do this?
    Jun 2011
    its coming from an ethernet connection. process is as follows...
    Edit mode...Program...optr...host...board.
    from there i can see the program that is on our server. which is an odd way to see it, considering we have to rename the post. removing the .nc extension. then we are able to see it on the system controller. for the life on me i cant figure out how to select the program from the HD-DIR so i can run the cycle or edit post.
    i really appreciate your help and time as well
    ok... finally figured it out. i wasnt navigating through the soft key menu far enough to select the proper program. thanks again, for your time. This is an awesome community. Im glad to be a part of it!
  1. Replies: 5
    Last Post: 03-09-2011, 10:11 AM
  2. Need Help!- Fanuc 6M Controller
    By QUALMACH1 in forum Fanuc
    Last Post: 02-03-2011, 10:02 AM
  3. fanuc controller
    By nwms in forum CNC-Zone
    Last Post: 12-09-2010, 12:07 PM
  4. Need Help!- Fanuc OT controller
    By kantaras in forum Mastercam
    Last Post: 11-21-2010, 07:48 PM
  5. Fanuc 15m controller
    By bigfoot in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-02-2009, 11:20 PM
