Results 1 to 4 of 4
Thread: doosan s310n tail stock
    Mar 2011
    we have a doosan s310n cnc lathe with a manual tail stock but we do not know the correct way to program it in is there a code to send it home so you can flip the lever and drag the tail body out. Do i have to put a code in that tells the machine its ok i want the lever flipped so don't set alarm saying check lever. we have had this machine for 4 years and never used the tail stock because we had a machine with a automatic. we use gibbs cam for our programs then edit them in predator editor so we just need a example of using the tail stock in code form ect. any help would be great thanks zed
    Mar 2011
    well i got it to work i did have to unplug a safety feature. it is a sensor that tells you to look at the lever that takes the tail stock to its position because i did not know the proper procedures to use it. i figured out what my distance was from my z zero to the location that i need to pick up the tail stock body and put that in so all in all i have 4 M0 and lots of flipping levers and tightening and loosening the tail body. so if any one knows the proper way of using your tail body in this kind of machine i am still all ears until then this will have to work.
    Apr 2011
    UK
    Normally, I would use T1, program it to send it home to pick up the tailstock (where it should always be!), I have only used ones with the pins to drag it. Cannot remeber the exact M code, should be in your manuals.
    G28W0.
    MCode for Pin
    G01 Z(Find Z value, usually 0 works well if the quill is not too long) F2000
    M code for pin retract
    M code for quill
    Then just the reverse.
    If it s a manual, then you will need to M0 instead of the pin to pick it up.
    Mar 2011
    thanks phillydee i will give this a try much appreciated
  1. tail stock
    By vgilbertson in forum Shopmaster/Shoptask
    Last Post: 12-31-2010, 10:37 PM
  2. Camlock Tail-Stock
    By eartaker in forum Mini Lathe
    Last Post: 10-15-2010, 12:21 PM
  3. Need Help!- TAIL STOCK
    By bruiserba in forum Okuma
    Last Post: 12-05-2009, 07:17 PM
  4. Need manuala for Doosan S310N CNC lathe
    By redfishoil in forum Daewoo/Doosan
    Last Post: 09-04-2009, 02:50 AM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-19-2004, 10:16 PM
