Results 1 to 6 of 6
Thread: Spindle Lock code???
    Mar 2011
    Doosan v420 VTL... Control- Fanuc 18-T.. Anyone now the spindle lock code? I have no book!
    Registered MysticMonkey's Avatar
    Mar 2009
    Wasn't sure what you meant by Spindle Lock Code.
    But here is the M-Code list
    Attached Thumbnails Attached Thumbnails Spindle Lock code???-pages_v420v420tope_0018.pdf
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
    May 2007
    I'm not familiar with that machine, but M19 is a spindle orientate code. Try it. Maybe it will lock the spindle for you. I assume it is a vertical lathe. Does the machine have C-axis? Our 200MS lathes have a C-axis button. Activating it locks the spindle.
    Jul 2005
    uk
    Quote Originally Posted by bolduc04253 View Post
    hi
    my Daewoo 350M with 18T is as follows:
    M88 low pressure spindle clamp
    M89 high pressure spindle clamp
    M90 unlock spindle clamp
    hope this helps
    regards
    axis
    May 2007
    M89 will definitely lock the spindle!
    Don't know why I didn't think about the clamping codes.
    May 2011
    Exclamation Help re-setting/re-starting Daewoo V3016.
    I have a Daewoo DMV3016 Fanuc i series Mill. During a run the machine stalled out causing an alarm. Spindle Tool clamp/unclamp error. Alarm # is AVE 0166. Anyone have an idea how to reset this and get running again. Never had this happen before. Thanks alot, Any advice would be awesome.
    1. Spindle wont Lock
      By nickmill13 in forum General Metal Working Machines
      Last Post: 07-14-2010, 07:57 PM
    2. Need Help!- Spindle lock
      By Larry Myers in forum Sharp CNC
      Last Post: 06-15-2010, 11:04 PM
    3. Code to lock feedrate?
      By walshsimmons in forum WoodWorking
      Last Post: 05-11-2010, 07:01 AM
    4. Spindle Lock for SX3
      By Old Megawatts in forum Syil Products
      Last Post: 05-01-2007, 06:19 PM
    5. m-code for spindle lock
      By fisholie in forum G-Code Programing
      Last Post: 12-17-2004, 06:21 PM
