Are you using a floating holder? could you post your code so we can help you better
What is the code that is best for tapping 5-40 thread on puma240. I tryed G84 ,G32 I must be missing something. The taps are breaking hole size is .105.Drilling .690 deep tapping .500deep.
machines cant rigid tap, that I am aware of. We just use a G1. With a floating head make sure you use a feed rate a couple thousanths slower than the lead of your tap. and when you reverse your chuck to retract use a feedrate a couple thousanths faster than you lead. Also remember that if you want to achieve a thread 1/2" deep you may need to make your tap feed just a little less than that so that when the turret stops moving and the chuck comes to a stop it wont go to deep
example
g0g54t0101
m3s250
x0z.1
g1z-.48f.023
m5
g4x1000
m4s250
g1z.1f.027
g0x10.z10.
t0100
m1
O1500 (M/SP RIGID TAP)
T0303 G40 G80
G99 G0 G54 X0.0 Z10.0
M29 S500 (RIGID TAP, SPEED 500RPM)
G84 Z-20.0 R10.0 F1.5 (TAP CYCLE)
G80
G0 Z50.
M30
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
