Results 1 to 2 of 2
Thread: Daewoo turret
    Jan 2011
    Daewoo turret
    Our Daewoo 200 has a problem with the turret not turning when the machine is telling it to it comes up with
    (operator Message)
    1. Tool indexing is not finishe
    d 2.F23 on/X30 off , Y28 on
    I unpuged the 18-8 plug going to the solenoid valves to check it out and the same stuff came up when the plug was unpluged.
    Registered MysticMonkey's Avatar
    Mar 2009
    for some reason the turret is not un-clamping or it doesn't know it has.
    check
    1. Valve Coil (Impedance check)
    2. Valve Plug (Voltage check when turret is commanded to rotate)
    3. Valve ( Mechanically override the valve and see if the turret un-clamps)
    4. Un-clamped confirmation switch
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
  1. Daewoo Puma 300 lathe turret alarm
    By rollman in forum Daewoo/Doosan
    Last Post: 01-23-2013, 10:01 AM
  2. Need Help!- Daewoo Lynx 210 turret
    By SINUMERIKO in forum Daewoo/Doosan
    Last Post: 09-18-2012, 04:07 PM
  3. Daewoo Puma 230 Turret issue
    By atscnc in forum Daewoo/Doosan
    Last Post: 10-15-2011, 08:13 AM
  4. turret is lost on a daewoo puma 12 lathe
    By tnik in forum Daewoo/Doosan
    Last Post: 07-02-2010, 07:34 AM
  5. Need Help!- Daewoo Puma 12L Hydraulic Turret
    By MysticMonkey in forum Daewoo/Doosan
    Last Post: 07-08-2009, 04:44 AM
