Results 1 to 3 of 3
Thread: Doosan communication wire
    Jul 2008
    I have a Doosan 4020 and a 3016 with 21i MB controllers. They have RS232 ports. I need to make a cable (25 pin machine to 9 pin computer) to hook up to the serial 9 port on computer. Does anyone know what the pin out configuration should be?
    Registered bobsch's Avatar
    Oct 2008
    Here's a page describing standard RS232 wiring for both 9 and 25-pin connectors: http://airborn.com.au/serial/rs232.html
    Bob
    "Bad decisions make good stories."
    Registered dcoupar's Avatar
    Mar 2003
    Speedrider:
    You only need a 3 or 4 wire cable, shielded if possible.
    CNC PC
    DB25M DB9F
    1 <----- shield---- (no connection)
    2 <----------------> 2
    3 <----------------> 3
    7 <----------------> 5
    4 & 5 jumpered (CNC side only)
    6, 8 & 20 jumpered (CNC side only)
    Set your handshake to XON/XOFF or Software
  1. Running stepper motor wire with router wire?
    By basskitcase in forum DIY CNC Router Table Machines
    Last Post: 02-19-2010, 11:18 AM
  2. Wire EDM - Wire Type and Size
    By greenchair in forum General Metal Working Machines
    Last Post: 06-17-2009, 02:44 PM
  3. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 05:34 PM
  4. Need Help!- Doosan DVC 500
    By Jay H in forum Daewoo/Doosan
    Last Post: 10-03-2008, 10:32 AM
  5. doosan vtl
    By rags in forum Daewoo/Doosan
    Last Post: 06-22-2008, 03:05 PM
