If u can't see the rpm u cannot thread ever. Off the top of my head I can't remember the parameter for turning on and off the spindle encoder but I think it's 7041 ish never the less you can't thread unless the encoder is showing up with a count. If not parameter get a new encoder if new encoder doesn't do trick check ground wire off encode cable you,ll find that attached to frame directly underneath the drive cable is connected to.
LinkBack URL
About LinkBacks
