Results 1 to 6 of 6
Thread: changing gears low to high M41-M43
    May 2010
    Question changing gears low to high M41-M43
    Hi, Can someone please tell me about gears changing (low/high) on a PUMA 2500xy. Such as importance in spindle life and spindle speed acceptable for low and high gears. I see that M41-M43 are codes to change gears but when I use these codes in my program it just stops on that line. Are there additional codes required? I've searched the internet about this and can't seem to find an answer. Please post example program.
    Oct 2008
    Just wonder, did you call M5 before M41?
    Ahn Vuong
    Registered dcoupar's Avatar
    Mar 2003
    I'm pretty sure you need to program M61 (low speed) or M62 (high speed) to change over the spindle windings. You don't have a gearbox, so M41-M43 have no function.
    May 2010
    Thank you for your response. Would you know what the desired spindle speeds are for low and high gears?
    Mar 2003
    I believe M61 goes up to 900 RPM.
    Registered chucker's Avatar
    Nov 2007
    I beleave if you have k5.7 set to 1 then it switches by its self at the correct rpm
    1. Just IN- High Precision, High Speed Bearings
      By mikeyg in forum Product and Manufacturer Announcements
      Last Post: 09-07-2009, 08:06 PM
    2. High voltage & high power servo drive design
      By Xerxes in forum Granite Devices
      Last Post: 08-22-2008, 10:24 PM
    3. High Torque , High Bandwidth Motor or Servo
      By mastabib in forum Benchtop Machines
      Last Post: 09-26-2007, 03:09 AM
    4. 8' high mill through a 7' high door?
      By iandm in forum Bridgeport and Hardinge Mills
      Last Post: 11-21-2006, 09:12 PM
