I am assuming that your Thread Milling on the Face of a Part.
Is this a Fanuc Control, if so which series?
Also i am assuming that you want to use a Hob End Mill, What Diameter??
I NEED A THREAD MILL PROGRAM TO THREAD A 1/4 -18 FEMALE THREAD IN 316 SST. YES I KNOW I CAN SINGLE POINT BUT TOOL LIFE IS TERRIBLE I WANT TO USE MY Z AXIS LIVE TOOLING AND THE C-AXIS.
THANKS
BAD DOG
DAEWOO 240 MSB
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
YES---FEMALE THREAD, FROM FACE,,,,, .292 CUTTER DIAM.,,,,, FANUC 18 i CONTROL
WE MACHINE A LOT OF 316 SST,,,, WE USUALLY 2ND OP THESE IN THE VMC BUT I NEED TO HAVE THEM COME OFF THE MACHINE COMPLETE.
THANKS,
BAD DOG
Do you have a Full Y Axis instead of using the C Axis??
If so, how much travel do you have?
Toby D.
Schwarzwald
NO Y-AXIS THAT IS WHY I WANT TO TRY USING C AND LIVE Z AXIS TOOLING
BAD DOG
Does your C-Axis Program in Degrees or an Inverted Scale??
Toby D.
Schwarzwald
POLAR,,,,,,,
Crap!!!
LOL, post this in the Mastercam area, maybe someone there can help.
Sorry.
Toby D.
Schwarzwald
HEY,,,,,
THANKS ANYWAYS. I JUST MIGHT TRY IT LONGHAND.
BAD DOG
I run this on my Puma 2500 SY
1/4-18 PITCH N.P.T. THREAD MILL USING C AXIS AND LIVE TOOLING
N30T1111(27/64" DRILL)
M24
G99
G54.1P1
G97S1500M3
G0X0.Z1.M8
Z.1
G1Z-.945F.004
G0Z1.M9
M5
M1
N40T0909(1/4 N.P.T. REAMER)
M24
G99
G54.1P1
G97S1000M3
G0X0Z1.M8
Z.1
G1Z-.9F.012
G0Z5.M9
M1
N50T0707(3/4 45 DEG. CHAMFER)
M24
G99
G54.1P1
G97S3000M3
G0X0Y0Z1.M8
Z0
G1Z-.185F.006
G0Z5.M9
M1
N60T0808(18 PITCH N.P.T. THREAD MILL)
M24
G54.1P1
S2315M33
G0X0Z.1C0M8
G98
G1Z-.6F50.
X.168Z-.5725H180.F7000.
Z-.5169H360.
X0Z-.4891H180.
G0Z5.M9
G99
I know this is an old thread but have you figured it out? I just had success programming a thread mill but using Cartesian to polar coordinate transformation on my fanuc control wouldn't work.use the y axis trust me. That way you can use the radius offset in your offset page which controls the y axis to control the dia like g41 cutter comp on a mill works.i can post an example if u want.im just replying to put the info out here in case you come across this again or it helps someone else.Best of luck
