- Need Help!- Doosan Lynx220LSY Sinumerik 828d TLM
Hello,
I'm working with Doosan Lynx 220LSY with siemens Sinumerik 828d.
I'm trying to start up Tool load monitor (TLM) but it seems like it doesn't work or work how it should be.
I recorded dimensions, selected proper axis on each tool that needs to be monitored and recorded current.
Later when TLM starts to monitor things, it detects broken tool even before machine starts to cut working area, so I lowered the min. tolerance then it goes ok.
But it doesn't detect realy broken tool (I tried cutting with broken insert and TLM does nothing) I even adjusted Max tolerance and so far no good.
Does anyone have some instructions or advice how to use it properly?
Re: Doosan Lynx220LSY Sinumerik 828d TLM
on the fanuc control you need to put M200 (TLM off) at the beginning of the program. Put in M201 right at the cut and M200 again to turn it off.
Here is a link to the manual I found: Operation Manual DOOSAN Tool load Monitor for Turning Centers (DTML) Release Version 3.X Under-load detect version - PDF
- You may not post replies
- You may not edit your posts
Forum Rules
