What is the serial number?
What is the Electrical Diagram number?
Both of these can be found on the placard on the back of the machine.
dear all,e
Can anybody help me by providing mechanical (turret assembly diagram)& electrical (turret control kwangwoo page 1-2) manual for lynx 210B daewoo cnc lathe ? i was suffering from turret encoder setting as turret disc slip by one station. can anyone guide me for this.
thanks
No longer with Doosan Machine Tools America
darrylhardt@gmail.com
- it has missing .
yesterday I tried turret indexing it works perfect in one direction but when tries in second direction it jumps into the next tool. And before clamping it shifts to next. it found little bit faster tool changing motion.
I had only change the o ring in turret assembly and found in trouble
thanks
Requested pages
thanks buddy! it will really helpful to me. if you have turret assembly drawing then please send me this as I am not getting place to fit the attached solenoid locking pin. if I got the page of 12- station turret drive then I could able to fit this part in assembly. it will be available in mechanical manual. I have uploaded the pic also so please kindly go through this and let me know.
I appreciated your support as you did the great job for me by giving this pic.
thank you once again.
See attachment
can any one guide me as I have not yet solve my problem? my problem is turret indexing speed seems to be very fast & gives hammering sound while rotation and it jumps to next station when called which gives alarm 2023 - Each tool indexing is not finished within 10 sec after tool index command (manual or auto)
I have reduce the hydraulic pressure but whole system pressure get reduce. is there anything which reduces the hydraulic pressure in indexing motor ? how pressure reducer solenoid works? don't exactly recognized the issue. I have one solenoid part which is not fitted in assembly the person is saying this is not the part assembly. I am attaching the pic of that part solenoid pin.
please suggest and support me
Dear Sir,
i need Daewoo Lynx 210 ladder software ,..
GOOD DAY, I WOULD LIKE TO SUPPORT ME WITH THE CONNECTION DIAGRAM OF THE 19 PIN CONNECTOR THAT IS LOCATED ON ITS LEFT SIDE OF THE SPINDLE. IT IS A CONNECTOR OF THE ENCODER THAT HAS A BAND IN THE TRANSMISSION.
THANKS
FORGIVE MY ENGLISH
