Hi
I have just completed a sprip down of the live tooling on a Puma 280 due to some sheered bolts. Mechanially all is in line so I just have to set up the motor.
I found this on the forum
Set Keep Relay 0.6 to a 1.
Using "Single Block" will move the Stopper Cylinder in/out.
Set #4077 S3 until Stopper Cylinder and detent are aligned.
Check that the Live Tooling drive is correct. If not you will have to adjust the cam with the Span Ring. Then repeat the above.
In this case or parameter is S2 - anyway once I have changed the parameter how do I get the motor to move to the new position so I can check alignment to the detent?
thanks
Wayne
