- TT1800SY teaching MISC buttons?, Optional stop allowing both paths to run to M01?
Does anyone have the documentation on how to slave a misc button on the TT1800SY control to an M-code- such as chip conveyor run M24, or chip conveyor stop M25?
Also does anyone know what parameter to change to allow the TT1800SY to process an M01 button press as a request to allow both paths to run to M01? Currently our machine is running one path to M01, and the second path (whichever took longer running) freezes when the first path hits Optional stop.
This leaves our machinists uncomfortable running the machine, and we are in a holding pattern unable to continue our first prove out. We don't want to run a machine that can't be stopped for an in process check if an odd noise is heard or if an operator suspects a tool has broken or is not performing properly.
We also don't want to use timing wait codes to synchronize all M01's, because this would require even more programming complexity than we already have, and would cost cycle time as one path waited for the longer opposing path. The operations are not equal in cut time from top to bottom in program run.
Re: TT1800SY teaching MISC buttons?, Optional stop allowing both paths to run to M01?
Doosan and Ellison had a different ladder to upload to make M01 functional. This situation is resolved now. It's like magic to see it run 2 paths to M01 now, but before I experienced this I took M01 for granted as a standard feature that would always be there when you need it.
- You may not post replies
- You may not edit your posts
Forum Rules
