- Feed hold stops spindle
2004 doosan puma 240 fanuc 21i tb anybody know what keep relay I need to change so the spindle dont stop when using feed hold? thanks
Re: Feed hold stops spindle
I believe it's K3.0 (there should be a list of keep relay settings in the "blue book").
From the operator's manual:
K3.0 Set "0" Feed hold operates but spindle and coolant don't stop.
Set "1" Feed hold operates and spindle & coolant stop.
However, in case of executing fixing cycle for thread cutting
or tapping, operation will be stopped after finishing
actual machining part.
Thanks dc you are rite on the money, works the way I want'ed it to, dont know why anybody would want the spindle to stop with a feed hold but anyway thanks again!
You're quite welcome. I remember the first Doosan (Daewoo at that time) I ran, I thought, "How handy, I don't have to stop the spindle and coolant!" That feeling lasted about 2 minutes into proving out my first program. Then I thought, "What a PITA!"
I have a 8s and a 10hc. The 8s spindle stops the 10hc doesn't. I quite like that it stops. Great to clear a bird's nest or change an insert mid rough cut. Check clearance to the jaws in dry run.
The worst part is if you open the chuck during this feed hold condition as soon as the chuck closes the spindle starts up. That is down right dangerous.
- You may not post replies
- You may not edit your posts
Forum Rules
