- Need Help!- DOOSAN PUMA 240 MACRO CODE
I have 2 daewoo (lynx 200 and puma 200) with 18T control year 1989 and 2000 , and i use the following macro variables to set the offsets on the machine , i need to find out if the same numbers will work on the DOOSAN puma 240 i0 control year 2013
i cant find it on the manuals i get with the machine ,
using this on the program will set all the work offsets i need without to go and set them manually
#2601=-9.0660(W-S)
#5222=0(G54)
#5242=-.32(G55)
#5262=-.640(G56)
#5282=-.960(G57)
#5302=-1.28(G58)
#5322=-1.6(G59)
Re: DOOSAN PUMA 240 MACRO CODE
- You may not post replies
- You may not edit your posts
Forum Rules
