Problem Doosan puma with lns bar feeder
Results 1 to 2 of 2
Thread: Doosan puma with lns bar feeder
    Jun 2017
    Default Doosan puma with lns bar feeder
    Need help with a program for a doosan puma 2000sy with fanuc 18i control really need help with a program for bar feed and bar change for this machine
    Member dhardt's Avatar
    Feb 2013
    Default Re: Doosan puma with lns bar feeder
    The external M-codes of the 18i era were either M50~M53 or M91~M94
    You can search you ladder for those to see how it is being used, and what I/O it connects to, from that you can trace the wiring from the I/O to confirm it is working.
    Finding the M-code and checking the status of Keep relays associated with the barfeed (K7.0~K7.5?) Should let you track whichever bit is active to see what the ladder requires.
    Any program that any end user would supply for a machine of that time, would be a shot-in-the-dark, and has just as much chance of not-working on your machine...and wasting your time...
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
