Puma 8HC-3A gear shifter seal kit needed
Results 1 to 8 of 8
Thread: Puma 8HC-3A gear shifter seal kit needed
    Jan 2008
    Default Puma 8HC-3A gear shifter seal kit needed
    Our Puma 8HC-3A is leaking hydraulic fluid around the actuating cylinder that moves the gear shift shaft in the head stock. We do not have any mechanical manuals, so we don't really know what is required.
    Any help in guiding us to a dealer that can help up out?
    Cheers,
    Steve E
    Member dhardt's Avatar
    Feb 2013
    Default Re: Puma 8HC-3A gear shifter seal kit needed
    Where are you located?
    What is the serial number?
    Last edited by dhardt; 04-07-2017 at 10:15 AM. Reason: I asked the wrong question...
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
    Jan 2008
    Quote Originally Posted by dhardt View Post
    We are located in South East Kansas. Machine Serial: 520005
    Steve
    Feb 2013
    Your dealer is Machine Tool Specialties
    918-622-0018
    I checked with the books I have on file for that series, I can't find anything on a gear-shift for the Main Spindle. Everything I found was motor to belt/pulley...no gearbox.
    Send a picture and I'll try to find a comparable unit.
    Jan 2008
    Puma 8HC-3A gear shifter seal kit needed-img_4436-jpg
    Shots of the shifter cylinder dis-assembled.
    Steve
    Attached Thumbnails Attached Thumbnails Puma 8HC-3A gear shifter seal kit needed-img_4437-jpg
    Feb 2013
    Our spindle specialist has never seen this set-up.
    He wants to contact the Korea Factory.
    He needs a picture of the Placard, showing the model and serial number for Korea to address an issue with a machine this old (their policy, not mine)
    Please send a picture of the placard to darryl.hardt@doosan.com
  7. #7
    Jan 2008
    Pictures are off & on their way.
    Steve E
  8. #8
    Feb 2013
    Email changed to: darryl.hardt@doosanmt.com
