Douglas, our Apps Engineer, thinks there might be something in "how" it is being done.
He is prepping a presentation right now, could you post the program code so he can see it when he comes to reply?
set up a job today, have a live "z" end mill doing a trepan circle using x and y , indicated end mill in to zero, cut the part and the circle is off, cutting more on one side then the other? its in 6061 alum. head stock off, turret off, loose live tool holder, maybe backlash? any ideas? thanks.
No longer with Doosan Machine Tools America
darrylhardt@gmail.com
Here's the whole program, thanks
O4596( 14596 OP1)
(ACTUATOR PISTON)
(REV A/ TOP VIEW)
(3.0 DIA X 1.335 LONG ALUM)
(ALUM JAWS .220 DP. MAX 160 PSI)
G0G18G20G40G80G99
G53X13.Z15.
M90
M34
M110
M262
M1
N1(R.TURN 80 DEG 1/64 RAD)
T0101
M24
G50S2500M8
G96S900P11/M3
G54
G0X3.2Y0Z.1
Z0.005
G1X-0.0625F.008
G0Z.1
X3.
G71U.1R.02
G71P100Q101U.01W.003F.01
N100G0X.55
G1Z-.087
X.751
Z-.768
X2.871
Z-1.11
N101X3.
G0Z.1M9
G53X13.Z15.
M25
M1
N2(F.TURN 80 DEG .008 RAD)
T0202
G50S2500M8
G96S900P11/M3
G54
G0X0.77Z.1
Z0.
G1X-0.0313F0.004
G0Z0.1
X.526
G1Z0.F.004
X0.55,C.012
Z-0.087
X0.6787
G3X0.7058Z-0.0948I0.K-0.0157
G1X0.7458Z-0.1295
G3X0.75Z-0.1373I-0.0136K-0.0078
G1Z-0.768
X2.8397
G3X2.871Z-0.7836I0.K-0.0156
G1Z-1.11
X3.0134Z-1.0503
G0Z.1M9
G53X13.Z15.
M1
N3(SPOT DRILL 1/2 x 90)
T0606
G50S2500M8
G97S2000P11/M3
G54
G0X0.Y0Z0.1
G1Z-.185F0.005
G4U.3
G0Z0.1M9
G53X13.Z15.
M1
N4(DRILL LETTER R .339)
T0404
G50S2500M8
G97S2500P11/M3
G54
G0X0.Y0Z.1
G83Z-.524Q2500R-.08F0.006
G0G80Z.1M9
G53X13.Z15.
M1
N5(3/16 DRILL)
T0808
G50S2500M8
G97S2750P11/M3
G54
G0X0.Y0Z.1
G83Z-.75R-.5Q1000F0.006
G0G80Z.1M9
G53X13.Z15.
M1
N6(TAP 1/8 BPST)
T2020
G50S2500M8
G97S500P11/M3
G0X0.Y0Z.15
M29
G84Z-0.445R0F0.0357
G0G80Z.15M9
G53X13.Z15.
M1
N7(GROOVE O.D. .118 WIDE)
T0303
G50S2000M8
G96S800P11/M3
G54
G0X3.072Y0Z.1
Z-0.9785
G1X2.508F0.003
G0X3.072
Z-0.9335
G1X2.508
X2.5304Z-0.9447
G0X3.072
Z-1.0235
G1X2.508
X2.5304Z-1.0123
G0X3.072
Z-0.8518
X3.0134
G1X2.871Z-.9158F0.003
G3X2.845Z-0.9285R.013F.001
G1X2.498F.003
Z-0.9785F0.006
X2.5098Z-0.9726
G0X3.0134
Z-1.0415
G1X2.871F0.003
G2X2.845Z-1.0285R.013F.001
G1X2.498F.003
Z-0.9785F0.006
G0X3.0134
Z.1M9
G53X13.Z15.
M5P11
M1
N8(E.M. 1/2 ALUM LIVE Z)
(**NOTE 2 OFFSETS**)
T0505(.751 DIA MINUS IS SMALLER)
M35
G17
G28H0.
G50C0.
G0C0.
M89
G50S2500M8
G97S2500P12/M3
G54
G98
X-1.295Y-0.01Z.1
G1Z-0.7F30.
G1Z-.915F5.
G41X-1.275F15.
G3X-1.255Y0.R0.01
G2X-1.255Y0.I0.6275J0.
X-1.2544Y0.02R0.6275
G3X-1.2738Y0.0303R0.01
G1G40X-1.2937Y0.0306
G0Z.1
X-1.291Y-0.01
G1Z-0.7F30.
G1Z-.915F5.
G41X-1.271F30.
G3X-1.251Y0.R0.01
G2X-1.251Y0.I0.6255J0.
X-1.2504Y0.02R0.6255
G3X-1.2698Y0.0303R0.01
G1G40X-1.2897Y0.0306
G0Z.1
T0525(1.850 DIA MINUS IS BIGGER)
X-1.306Y0.01
G1Z-0.7F30.
G1Z-.915F5.
G41X-1.326F15.
G3X-1.346Y0.R0.01
X-1.346Y0.I0.673J0.
X-1.3454Y-0.02R0.673
X-1.3248Y-0.0297R0.01
G1G40X-1.3048Y-0.0294
G0Z.1
X-1.31Y0.01
G1Z-0.7F30.
G1Z-0.917F5.
G41X-1.33F30.
G3X-1.35Y0.R0.01
X-1.35Y0.I0.675J0.
X-1.3494Y-0.02R0.675
X-1.3288Y-0.0297R0.01
G1G40X-1.3088Y-0.0294
G0Z.1M9
G53X13.Z15.
M90
M34
M5P12
G18
G99
M1
N9(CHAMFER 1.85 TREPAN DIA)
(3/8 BORE BAR 1/64 RAD)
T2222
G50S1500M8
G96S375P11/M3
G54
G0X1.99Y0Z.1
Z-.7
G1Z-.768F.003
X1.845Z-.83
X1.83
G0Z.1M9
G53X13.Z15.
M30
Pos:
The reason for the lack of circularity accuracy is that you are at the end of Y axis travel and therefore the machine cannot quite "make it" through the whole contour of the part. Even in M110 interference check off mode the machine can't physically make it around the groove.
I recommend using G12.1 Polar Coordinate Function. This will overcome the physical limitations. I have examples if you need.
-Doug
Doug, thanks for the reply, that sounds right, but after i seen that the circle was not centered I went to C "0" (the same place it cut the circle) with out taking the part out and checked to see where it was off in x and y then offset the x and y accordingly, the next part was good? Maybe I couldn't get it in with the "R" comp but was able to with the x and y offsets? even with the M110 on you would think the machine would alarm out if it was that close to the end of travel, but ? yes please send me examples of the G12.1 thank you all for the help!
You're welcome and it would be a pleasure.
Please PM me and I'll email it out in PDF format.
