- Need Help!- Doosan DNM650 II Fanuc 32ia Large tool offset
Hi!
Where to tell which pots are empty and what tools are with large diameter and what are normal tools?
-Under Key "CUSTOM1" there is just pot number and tool number table.
-Under diagnostic parameter there was Gdata in earlier Fanuc but im not able to find it from this new machine.
Already tested D480 but when ZOOMing it there is only one number, no place to put pot numbers.
Also there is text "TM is off", could this stand for tool management ?
These new Fanucs are not getting easier....
Anyone?
-GB
Re: Doosan DNM650 II Fanuc 32ia Large tool offset
Tool Management utility is activated by first activating the Tool Utility under "Custom 1" and then placing the machine into Emergency Stop mode. A soft key choice "TM On" will appear at the bottom of the display. Press it, confirm by pressing "Y" and function will be on.
Reverse to turn off.
When on, other choices will appear including pocket assignment, tool names, etc.
PM me if needed.
-Douglas J. Rizzo
Training Coordinator
Doosan Machine Tools.
Thanks Douglas!
"Emergency Button" was the Magic Word.
Have a nice day,
-GB
- You may not post replies
- You may not edit your posts
Forum Rules
