The problem with moving a machine is risk knocking it out of level and squareness. You will need to get someone it there with a level and check the squareness. Also, make sure the foundation of where you moved it to is the same as where you moved it from. Also, if you have pitch error data you may have to re laser the axes and readjust the pitch error.
