Doosan Tech-Docs and Service Bulletins - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: Doosan Tech-Docs and Service Bulletins
  1. #21
    Member dhardt's Avatar
    Feb 2013
    Default Re: Doosan Tech-Docs and Service Bulletins
    This applies to the Newer Doosan MX Series
    MX2100
    MX2600
    MX3100
    The ATC Recovery procedure:
    Attached Thumbnails Attached Thumbnails Doosan Tech-Docs and Service Bulletins-tec2008-44-pdf
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
  2. #22
    Feb 2013
    Flow chart for regular turret maintenance
    Attached Thumbnails Attached Thumbnails Doosan Tech-Docs and Service Bulletins-tec2010-28-pdf
  3. #23
    Feb 2013
    APC 300 Alarm on a lathe
    How to reference home with an Absolute Position Coder (APC)
    Attached Thumbnails Attached Thumbnails Doosan Tech-Docs and Service Bulletins-tec007-03-pdf
  4. #24
    Feb 2013
    To address the Periodic Maintenance Alarm
    tec2008-30.pdf shows how to clear the alarm
    tec2008-46.pdf shows how to set/change the times and add/remove line items
    Attached Thumbnails Attached Thumbnails Doosan Tech-Docs and Service Bulletins-tec2008-30-pdf   Doosan Tech-Docs and Service Bulletins-tec2008-46-pdf
  5. #25
    Feb 2013
    B-Axis overhaul for an Old Style MX
    MX2000
    MX2500
    Attached Thumbnails Attached Thumbnails Doosan Tech-Docs and Service Bulletins-tec007-16-pdf
  6. #26
    Feb 2013
    How to Reset the Home position on ANY Doosan Machine.
    (Note: for the exact numbers for your exact machine, you will need the Instruction Manual (AKA: maintenance and specification manual)
    This procedure shows how to gather all needed information and apply it correctly based on what hardware the machine has and the reason why the "Reset of Home" is needing to be done.
    Attached Thumbnails Attached Thumbnails Doosan Tech-Docs and Service Bulletins-machine-reference-recovery_all-forms_addended-pdf
  7. #27
    Feb 2013
    How to maintain and calibrate the Q-Setter on an Lynx 220:
    Attached Files Attached Files
  8. #28
    Member corelmachine's Avatar
    May 2019
    Dear Sir,
    I need the electrical drawing for the following machine:
    DOOSAN S 310
    FANUC- 21T
    SERIAL : LNF1109
    Kindly Let me know if you have them.
    Thanks,
    Atharva Rane
    info@corelmachine.com
  9. #29
    Feb 2013
    I don't know how else to answer your PM: as it won't let me...So I'll try this reply to something that you posted.
    In this thread is the "How to reference any Doosan machine"
    Call 973-618-2461 if you need to discuss further.
  10. #30
    Feb 2013
    Quote Originally Posted by Michael82
    whats ur email I checked my settings and they r all good it says I can get pm from everyone
    Darryl.hardt@doosanmt.com
    It is in the footer of every post I have...
    ...and you have emailed me before...
  11. #31
    Member Maint_Tech's Avatar
    Oct 2019
    Where can I find the procedure for replacing the clamp/unclamp solenoid on a Doosan LYNX 220 LM
  12. #32
    Feb 2013
    Quote Originally Posted by Maint_Tech View Post
    If you meant cylinder then this:
    Doosan Tech-Docs and Service Bulletins-actuator-drawbar-chuck-jpg
    if you are asking for a procedure for "replacing the...solenoid" they don't exist within Doosan...
    Here goes:
    1. Verify the replacement is correct.
    2. Take pictures and/or mark connections of previous unit.
    3. Remove previous unit.
    4. Install replacement unit.
    5. Verify the connections are correct.
  13. #33
    Feb 2013
    How to adjust reference position for the Power Mate Manager controlled ATC and Magazine of a Doosan MX machine:
