Results 1 to 5 of 5
Thread: I need a simple 2 axis program for Windoze.
    May 2005
    Looking for more uses for the electronics of my home brew CNC router and the left over parts. The router is running on Mach2 through the parallel port. I want to build a rig for winding carbon fiber tow into tubes on a mandrel and figure I could just come off the X and Y controllers on the router.
    It is a simple repeating routine for two steppers. Stepper A rotates the mandrel. Stepper B drives a carriage through a timing belt. Basically Stepper B rotates X times depending on the length of the tube at some ratio Y:1 to A determined by the diameter of the mandrel and the angle of the layup. At each end Stepper A rotates the mandrel some angle less than 360 to fix the tow and position it for the return. The cycle repeats for how ever many plys are needed.
    Anyone know of a simple program (preferably free) that can do this?
    Registered M250cnc's Avatar
    Sep 2007
    England
    Make your own program
    It's called G Code you can hand code it.
    With the G codes they may even be in Mach two on one of the buttons
    As this is a specialised application you will have to do it yourself.
    Phil
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    Just use Mach2, you already have the software.
    Then write the g-code, like "M250cnc" said.
    Free DXF Files - myDXF.blogspot.com
    Mar 2003
    Shelby Twp, MI....USA
    You can also make a custom Mach3 screen for your 2 axis application.
    May 2005
    Looks like I need to do some more study on G16. Never had occasion to adding my rotary table so never played with the A axis rotation.
    Guess I should also take a look at Mach3.
    1. Need Help!- BobCad-Cam V21.5 simple program
      By jessey in forum BobCad-Cam
      Last Post: 05-29-2009, 12:42 PM
    2. Need help with simple thread mill program
      By Captain Midnigh in forum Milltronics
      Last Post: 07-24-2008, 06:57 PM
    3. Need Help!- Simple loop program for mazak
      By katsbobo in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 04-07-2008, 07:11 PM
    4. simple part program
      By chevblue2 in forum G-Code Programing
      Last Post: 02-10-2008, 04:20 PM
    5. Simple G-Code program?
      By N4NV in forum G-Code Programing
      Last Post: 03-24-2006, 07:35 PM
