I need help, I can't seem to find where to insert the workoffsets in the controller. I know this sounds stupid. In the offsets there should be, in the sub-menu, a (Work) label beside the (Offset) but there isn't one. Does this machine use absolute only or is their something that has been changed in the parameters? Maybe a there's a parameter that truns it on and off? The only offset I can find is the Tool offset.
Any help would be great! Thanks!
Sounds like your restricted to G92 only but this can be change by parameters to give you G54 to G59 but you have to pay Fanuc![]()
