Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 05-20-2009, 06:44 AM
Viesturs is on a distinguished road
Axis movement speed adjusted by pressure sensor
hi!
i've been trying to search these forums, but without any luck in finding an answer.
i would like to construct CNC machine that would use diamond wire to cut granite stones in slabs.
the idea is to have pretty simple design with 2 axis - X axis - move back and forth and Y axis - move the wire up and down and do the cutting during downward movement.
my problem is that i do no know, how can i build it in a way that speed of this downward movement (when the cutting is conducted) is adjusted by the tension of diamond wire? what kind of pressure sensor should i use and how can i integrate it with a motor controller so that movement speed on one axis is adjusted so that tension of wire does not exceed certain limit?
those stones to be cut are very different sizes, so determining one certain speed that would work for all in more or less efficient way is unreal
cut speed / power settings / air pressure marcmnrsports CNC Plasma and Waterjet Machines 6 06-08-2011 09:22 PM
Z-Axis depth guide sensor ? deleteallusers Mechanical Calculations/Engineering Design 5 07-17-2007 12:38 AM
DIY pressure sensor ? - Touch Off Plate ? deleteallusers Mechanical Calculations/Engineering Design 4 06-22-2007 04:56 PM
Mounting a Speed Sensor on a BP step pulley mill titchener Bridgeport and Hardinge Mills 1 03-21-2006 05:02 PM
Installation of spindle speed sensor Bloy2004 General Electronics Discussion 7 01-27-2004 09:50 PM
