Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 05-05-2009, 05:44 PM
mactro215 is on a distinguished road
Red face newbie. what do i have?
I am a metal fabricator looking for a way to plasma cut parts and move to 3d milling later. I bought someones project on a whim and now i'm a little over my head. what do I need to make this work. the gantry is no problem, the electrical is making me crazy. my power supply puts out 27 volts, my motors are 65v dc bipolar 8 pin. I am pretty much a moron when it comes to electricity so don't feel bad about talking to me like a child, in fact please do. there should be attachments of the boards that I have. thanks ~mac
Old 05-06-2009, 11:31 PM
I don't know why my pictures didn't download.
Old 05-06-2009, 11:47 PM
MrWild is on a distinguished road
dump the motors and dump the supply. The motors are way over volt, and the supply under volt. Whie you might use the supply in a pinch, you won't get by at all with the motors.
Old 05-07-2009, 12:02 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
65v is probably the maximum voltage rating so a 48 v supply would probably do the trick as long as the motors have any amount of toque to them and the drivers can handle it
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 05-07-2009, 08:49 PM
do I need motor drivers outside of the hobby cnc board? what is a good voltage to work in and what are your recomendations for motors? thanks ~mac
Old 05-07-2009, 10:37 PM
these motors have a max of 119oz. holding power. do you think that even with gearing that these would move a 5'x5' setup at plasma speeds?
Old 05-07-2009, 10:46 PM
dertsap's Avatar
Gold Member
its pretty much impossible to answer your questions without understanding what youve got , what motors do you already have , what kind of driver , is it the hobbycnc ,'voltage is determined by the motor rating and what the drivers can handle, generally most motors can run up to 25 time the rated voltage (start rating) , at 65v your motors are probably showing the max rated voltage which you cant go beyond , if we know exactly what you have then we can probably help you to get setup properly and try to utilize what you already have
Old 05-07-2009, 10:47 PM
dertsap's Avatar
Gold Member
i highly doubt it , your going to need bigger motors
Old 05-11-2009, 08:46 PM
the board is 42v. ok, I think the pictures went through. I also have a random z axis board and head assembly. I have heard that running a plasma on the hobby is fine. true? also am I doomed trying to use a vista os?
Name:	hobby cnc board.JPG‎
ID:	81199   Click image for larger version
ID:	81200   Click image for larger version
Name:	relay board.JPG‎
ID:	81201   Click image for larger version
Name:	z board.JPG‎
Old 05-11-2009, 08:51 PM
I don't have instructions for the board. do I simply plug the board into the power supply, in the right polarity, then run the printer port protector inline, and wire straight to the motors from the hobby cnc board? I'm confused about amp requirements in relation to the board. <---electricity is not my strong suit.
Old 05-11-2009, 09:19 PM
dertsap's Avatar
Gold Member
connect the dc power to the hoccycnc board , then connect the motors to the board , there is a hobbycnc forum where you'll be able to get direct help for that board , picture #3 is a relay break out board which you won't need since the hobby board doesnt need a BOB
out of curiousity did you buy the gear from a member of the zone because i chatted a while back with another guy who more or less had all the same stuff
  #12   Ban this user!
Old 05-12-2009, 05:47 PM
the guy I bought this stuff from did recommend the site. I should have known better. he was liquidating his shop and I had money. everything worth anything wasn't for sale. thanks for your help. I think that I'm going to get three new motors (2 for "y") and use the existing z axis. as far as amperage goes, is this correct... whatever the total amperage draw of all motors= amperage output of power supply?
Newbie miketobydog Laser Engraving & Cutting Machines 0 09-04-2008 04:30 AM
Newbie says hi jacobavera CNCzone Club House 2 04-19-2008 12:03 AM
Newbie Closetolerance Benchtop Machines 2 12-12-2005 03:06 PM
Any help for a newbie? Jounik General CNC (Mill and Lathe) Control Software (NC) 12 01-12-2005 10:12 AM
Help this Newbie Please! Guy Smiley Xylotex 5 12-24-2004 12:57 AM
