Results 1 to 10 of 10
Thread: Mazak + DNC + Vista = Help
    Apr 2009
    Hey fellas,
    I have finally talked the boss into letting me try running our 4 axis mill from the PC.
    Trouble is, I'm not too sure on how to set it up properly.
    It's a Mazak VTC-20B with Mazatrol M Plus controller, it has a 25 pin port on the side.
    I'll be using a laptop running Vista.
    I guess I need to know if you can get a USB to DB25 cable, which DNC software is best, will Vista be compatible with M Plus, and any other pertinent info anyone can supply .
    I used to run an old 6M Fanuc from a PC so I have a basic idea on how to go about it.
    Thanks in advance from an old Aussie.
    Apr 2009
    Bump.
    (can I do that?)
    Registered SINUMERIKO's Avatar
    Sep 2008
    Home sweet home
    If your software runs ok in XP but not in Vista, I can give you some tips to make it work.
    Apr 2009
    ATM I have no software or anything.
    What I'ld like to know is what I need software & hardware wise to get up and running.
    Registered Rally's Avatar
    Jan 2007
    Quote Originally Posted by Sheba View Post
    Hey fellas,
    I guess I need to know if you can get a SUB to DB25 cable, which DNC software is best, will Vista be compatible with M Plus, and any other pertinent info anyone can supply .
    If you don't know what you are doing I can only say you have a brave boss!
    Laptops are also not my favorite. I prefer a trimmed PC.
    Vista is OK but it is better to strip it down to a bare minimum, judging by your comment, you are not looking to network.
    DNC Software???? What CAM package are you using?
    All comments made are my opinion!
    May 2007
    I have been using NCPlot to DNC to a 3 axis mill.
    Like the idea of seeing a plot of the tool path so I can do things like quickly add a G68 to spin the program around to match the fixture and get some visual feedback.
    The largest programs I have been running are in the 400 to 500 thousand char. range, so not real big by some standards.
    Apr 2009
    Quote Originally Posted by Rally View Post
    I will be using EdgeCam, but only to write the ISO code. We want to try and do some 3D profiling for a client that has it done elsewhere.
    All I need is a program to feed the M plus as it's memory is tiny and won't hold a lot of G-code programming.
    Will Vista be compatible, what cable do I need (it has to be USB to DB25) and what software to transfer the code.
    May 2007
    It is just RS-232 communications, hard to imagin an OS that would not work.
    You can get cheaper consumer grade converters but I would look at somthing a bit better, at least with isolation.
    http://www.bb-elec.com/product_family.asp?FamilyId=355
    These guys can also likly help you out with getting the right cable and configuration in the CNC machine, get a cheaper one and you will get no help from them.
    Apr 2009
    Thanks for the help so far and sorry if I'm being a plonker, but the CNC only has a 25 pin port on the side of the control to plug into, so a RS-232 wont work.
    The laptop only has USB conections unless I can use the monitor port?
    Jan 2007
    Not a problem there are adaptors available to do the job!
    Vista should work just fine I would still stripp it down to the bare minimum.
    I'm talking about services and such that are running in the background.
    Someone correct me if I'm wrong but I was under the impression that EdgeCam is capable to tramsfer data to a machine??
    as for the G-Code We also have a older machine running on G-Code but have not had a problem with memory yet.
    However NCPlot should work just fine.
    1. Newbie- Vista or XP ?
      By Farmers Machine in forum CamSoft Products
      Last Post: 10-25-2008, 06:58 AM
    2. Newbie- XP or Vista ?
      By Farmers Machine in forum Alibre Design
      Last Post: 10-24-2008, 11:41 PM
    3. MC 9 In Vista
      By phoodieman in forum Mastercam
      Last Post: 03-23-2008, 10:35 PM
    4. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
      By sting_dot in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 05-21-2007, 09:20 PM
    5. MS Vista?
      By prototect in forum Mach Software (ArtSoft software)
      Last Post: 02-24-2007, 05:31 PM
