Results 1 to 2 of 2
Thread: Time pulse, digital output of machine controller
    Feb 2009
    Germany
    Hello,
    I want to get time information at the execution of every CNC command line.
    Is it possible to get this time information using a digital output of machine controller (Sinumerik 840D by Siemens)?
    Perhaps a digital digital up/down pulse (every up may represent successful execution of CNC command) could be possible solution.
    thanks
    smar
    Jul 2011
    The controller constantly shares digital information in the kHz or Mhz range with the motor drive. Each pulse could be in the ns or micro second range. The slower Sinumeric would not catch each signal.
    The duration of each CNC step depends on the travel distance of each axis within that particular command.
    You can download Mach3 (German, English) and simulate axis speed of the mill you are using for the job in the motor tuning setting. The program will execute the job on the screen in exactly the same time the CNC mill will do.
  1. Are their controllers that output ASCII command(instead of pulse)?
    By JasonCampbell in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-25-2007, 06:49 AM
  2. Pulse generator / controller boards for EMC.. which one?
    By ewest in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2007, 06:53 PM
  3. Taig Mill, US Digital MS23, Controller???
    By marjamar in forum Taig Mills & Lathes
    Last Post: 02-07-2007, 10:16 AM
  4. US Digital MD1 Controller
    By Mooser in forum Stepper Motors and Drives
    Last Post: 01-21-2007, 05:51 PM
  5. Visual Basic Controller - pulse width?
    By dwwright in forum Visual Basic
    Last Post: 08-03-2005, 12:57 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
