Results 1 to 4 of 4
Thread: D&M-4 Machining Center Upgrade!!!??
    Oct 2008
    Hello Everyone, I have a D&M-4 Machining Center that needs to be upgraded. Has anyone done a retrofit or an upgrade of the drivers to run with windows.
    I don't have the old controller card, so I need to start from scratch. The machine runs very nice manually but I need to be able to use it as a CNC and not a manual machine. any help will be very much appreciated.
    Elias
    Registered vlmarshall's Avatar
    Mar 2006
    Yes! I swapped out the electronics in mine for the Xylotex 4-axis package, but ANY of the available stepper drivers will run the D&M Sherline.
    I changed the power supply and steppers as well, and added a relay control for the Puma spindle controller board.
    Recently I burned out that Puma while attempting to add a CNC4PC C6 speed control, and replaced it with a KBIC.
    What do ya want for the old stuff?
    Mar 2006
    You might want to check your leadscrews to see if your Sherline is converted from an early manual model like mine was. The manual mills don't support the leadscrews in bearings, and I had some galling and backlash issues until I added bearings. I didn't want to lose any travel inside the D&M enclosure, so the Sherline CNC parts weren't an option.Check this thread!
    Sherline cnc conversion videos
    That guy just posted a great video on converting a Sherline to CNC, and you can see the manual components, and the conversion parts, as well as a Xylotex driver in it's own enclosure.
    Oct 2008
    D&M Upgrade
    Thank you for the response. I found the video by Alan to be very informational.
    thanks again.
    Elias
  1. Need Help!- CNC Vertical machining center
    By soumen in forum Mori lathes
    Last Post: 03-11-2008, 10:06 AM
  2. new to cnc machining center
    By BruceinOZ in forum CNC Machining Centers
    Last Post: 08-11-2007, 02:25 PM
  3. HOW BIG IS YOUR CNC Machining Center?
    By boxxer_boy in forum CNC Machining Centers
    Last Post: 04-10-2007, 06:31 AM
  4. D&M 4 Machining Center
    By bill south in forum General Metal Working Machines
    Last Post: 07-17-2006, 06:21 AM
  5. New Machining Center
    By porsche1220 in forum CNC Machining Centers
    Last Post: 04-27-2006, 07:34 PM
