Results 1 to 6 of 6
Thread: MX-3 Yasnac Parameters
    Mar 2005
    We've just transferred programs from a 16M machine to a Matsuura with a MX-3 control. In doing so we discovered that the Matsuura MX3 doesn't have the axis rotational G68/G69 option. Can anyone tell me how to install and which parameter it is?
    Thanks!!
    Oct 2008
    CALL 1-800-yaskawa . they will help
    Mar 2005
    Thanks for posting. Actually because of the urgency of getting the job running I did contact Yaskawa. A serviceman visited for a short time and changed the parameter. In my opinion coordinate rotation is a handy tool.
    Dec 2005
    HOW MUCH THEY CHARGE YOU
    I HAVE SAME PROBLEMS WITH ONE PARAMETER ON A MX1 CONTROL
    Mar 2005
    They charge 120.00 per hour plus travel time, tolls, etc. If they are right around the corner then it's worth it, but the bill can go to 1300.00 if there is a lot of travel time. In any case the fellow was very good and didn't waste any time.
    Perhaps if you post your parameter issue someone on here can help you. Good luck.
    Dec 2005
    Quote Originally Posted by stude8 View Post
    i finally solve the problem , was a memory parameter 6041 it was ok but only show me small memory on the screen (after reload all parameters ) i have to erase all memory and that set , i call them and they wont tell me that, they want to send a tech... all the way to Florida to fix it .
    1. Need Help!- Yasnac LX3
      By inthedark in forum General Metalwork Discussion
      Last Post: 08-07-2008, 06:03 AM
    2. anybody speak Yasnac LX3?
      By Paul in OK in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-06-2008, 02:16 PM
    3. yasnac J 100 M
      By Furlan in forum Manual Machining Tooling
      Last Post: 11-17-2007, 10:55 AM
    4. need post for yasnac MX3
      By ARIF AHMED in forum Post Processor Files
      Last Post: 08-02-2007, 02:37 AM
    5. Yasnac I80
      By Gitanes in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-24-2005, 12:00 AM
