| Controller & Computer Solutions Discuss computers and setups for cnc controllers. |
Well I'm usually pretty good at figuring out things but I'm having a senior moment. I have a small router, hobby cnc control card, Mach 3. All I want to do is control the spindle on and off along with dust control at the same time using the M codes. I need some type of relay to connect to the control card.The problem is I can't seem to get it straight in my head just what I need and how to do this. You would think I could get this after completely building the router from scratch, assembling the control card and settng it all up .......but Duh!!!! can someone please send me down the right path? Thanks so very much. Ron |
Hi, I'm back again. I have the relay like Leeway posted in the post you directed me to Al. I have connected it to pin 14 and ground (pins18-25) on my BOB. I get 4.46 volts when triggered with M3 across the pins when not connected to the relay, but when I connect to the relay it drops to 1.46volts. The relay won't trigger. The pin connection on my board for pin 14 comes straight from the computer, my board does nothing to it except give me a place to hook to it. Do I need a pullup resistor here somewhere and if so where? Or am I doing something else wrong. Thanks for the help. Ron |
| Have you hooked the SSR up to pin 14 or are you using a buffer? Personally I would use a 2n7000 to buffer the port if you have not already. Al.
| Using Flashcut CNC Spindle rotate card control to control laser power | pyroplotter | FlashCut CNC | 0 | 10-15-2007 09:46 PM |
| Mitsubishi control help needed! | rogdog | Mazak, Mitsubishi, Mazatrol | 12 | 09-09-2007 01:54 AM |
| motor control needed | justlesh | Benchtop Machines | 6 | 07-22-2007 03:24 PM |
| EZPath DX32 control help needed, please!! | VSMIGuy | Bridgeport and Hardinge Mills | 1 | 01-28-2007 10:49 AM |
| Software needed for Tree VMC 760 control | popstorefixture | General CNC (Mill and Lathe) Control Software (NC) | 3 | 06-23-2006 01:16 PM |
