Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 10-12-2008, 07:25 AM
REVCAM_Bob is on a distinguished road
How to measure with a Galil card...
Hi all, I have a 2 axis galil card, that I think has some auxilary encoder inputs.
I am trying to figure out how to as "inexpensively" as possible measure the
bottom position of a block for flatness while it is in a fixture.
I have to be able to measure withing probably 0.0001" or 0.00005" would be better. The range is quite small probably less than +/- 0.010"
I need to figure out somehow to interface with a galil card also...
Any thoughts?
Thanks!
Old 10-12-2008, 08:01 AM
kevin swan is on a distinguished road
do you have a manual
Old 10-12-2008, 08:20 AM
Yes, I have a manual.
Old 10-12-2008, 08:50 AM
How do you usualy measure it. that is a small amount ?
Old 10-12-2008, 09:08 AM
Currently we have this fixture on posts which hold it suspended above
a surface plate.... (the posts are very accurately ground etc.)
then we use a 0.0001" dial indicator on a stand... not sure the name of it,
but its an indicator holder that slides around on the top of a surface plate.
we can run that indicator back and forth under the fixture that holds the detail, and tell how flat the detail is sitting in the fixture. This allows us to then make adustments to the block until it is flat.
I am trying to figure out how to measure this automatically.....
Old 10-12-2008, 10:48 AM
Al_The_Man's Avatar
What is the Galil card type? and do you intend using it purely for this function, IOW do you intend control or just measure?
What operator interface do you intend to use? Or just native commands.
Old 10-12-2008, 12:47 PM
Hi Al, I have an 18x2 card using it for 2 axis servo motor control, and
it has 2 encoders hooked to it now for the 2 drives.
I think it will accept another encoder input, if that ends up being the way to go.
The interface is a vb.net interface, but I also use the terminal windows with it
to do most of the code etc.
I could of coarse add more boards to the system if I have to... but then that also involves trying to get communication between programs etc....
thanks, Bob.
Old 10-12-2008, 12:52 PM
CarbideBob is on a distinguished road
What are you planning on measuring with?
I've done it two ways.
Use a DC output LVDT, wire the output to one of the ADC inputs on the Galil card. Scan the part and record the measurements. ( @AN[n] function )
If one axis is perpendicular to the plane to be checked wire a touch probe or touch switch to one of the latch inputs (inputs 1 and 2) and latch the encoder position while probing with the axis. (commands AL.. and RL.. )
Bob
PS: The 18x2 card (a two axis would be a 1822 card) is the econo series and doesn't support auxiliary encoders.
Both above methods will work on this card though.
You can always spot the pioneers -- They're the ones with the arrows in their backs.
Old 10-17-2008, 02:04 PM
Smile
Thanks Carbided Bob
Newbie- z0 measure albert.B Fanuc 4 08-29-2008 08:14 AM
Camsoft to 1030 Galil card jimtom CamSoft Products 2 09-02-2007 04:59 AM
Lots of Problems after reinstalling Galil card 69owb CamSoft Products 10 05-06-2007 10:09 PM
Need measure titoniks Industrial Hobbies (Support forum) 6 09-09-2006 02:27 PM
Measure Rpm jhwatts General Electronics Discussion 13 09-19-2005 12:08 AM
