Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 09-10-2008, 02:53 PM
jeff@rans is on a distinguished road
98 HAAS VF-3 communications
Hello all,
I just bought a new computer to program at my machine. I have all the communications hardware, and parameters set for my editor to transfer to my machine. The Haas still wont acknowledge any communications from my computer. This diskette transfering is killing my productions. Any one walk me through this?
Thanks Jeff
Old 09-10-2008, 03:12 PM
HuFlungDung's Avatar
Moderator
Is this a tried and proven cable from a previous setup? Always suspect the cable.
Also, don't plug a com cable into a computer printer port. Just because the plug fits, doesn't mean its the right port
Its always pin 2 and 3 that got to be checked or swapped over. See the Haas mill control book (xMcb.pdf) file from the Haas website, page93
Old 09-10-2008, 03:47 PM
We made sure of the cables first, all hardware is clean.Jeff@Rans
Old 09-10-2008, 11:55 PM
Moderator
I dunno, its either the cables, the software settings or maybe a dead serial port. You are using the correct serial port on the Haas, the top one not the bottom one, IIRC?
Are you using a laptop with a converter from USB? Those may not be reliable for a surefire test.
If your computer has a real serial com port, make sure it is enabled in BIOS.
Old 09-11-2008, 09:05 AM
Machine doesnt do anything, no alarms, when I try to send over the programs.
Old 09-11-2008, 09:26 AM
bborb is on a distinguished road
What happens when you try to send from the Haas TO the PC?
Old 09-12-2008, 07:54 AM
cnc editor doesnt acknowledge program from Haas either.
Old 10-08-2008, 12:46 PM
gm3211 is on a distinguished road
Can you provide us with the details parameters at the CNC and PC?
Also, you can get an RS232 line tester to verify you are using the correct comm port on the PC. Using a tester, you can punch from the CNC and see activity at 1 end; and then put the tester at the end of the cable to confirm data flow to the end.
Call me if you need help 619-461-4000 Greg
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
Old 10-08-2008, 02:11 PM
Thanks for your help, I had a Haas tech come out, and he couldn't get it straightened out. turns out, One of the wires two of the wires on one end, but not the other, were crossed in the cable.
Communications with R2E3 rkdygert Bridgeport and Hardinge Mills 15 03-28-2010 12:26 PM
VMC 3016 communications ttorqueshop Fadal 12 11-24-2007 11:23 AM
RS232 communications with VB6 nickz Visual Basic 6 12-13-2005 09:24 PM
RS232 communications cobrav18 General CNC (Mill and Lathe) Control Software (NC) 0 07-07-2005 01:46 PM
PDA Communications rfmerrill General Metalwork Discussion 0 02-09-2005 08:03 PM
