Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 08-04-2008, 10:36 PM
gunlocators is on a distinguished road
Best 4 axis and PC setup ?
OK I do Not want to build my controller. I am looking for the best 4 axis controller plus steppers for under $1000.00 I looking to as close to plug and play as i can get. I am building a modified Joes 4x4 in a 2'x4' footprint instead for pool cue inlays. The 4th axis will turn a taig 4 axis rotary table to hold pool cues.
Also I will be using probably mach 3 and vcarve for the software.
Last whats the best Laptop to use i perfer laptop over a desktop. I have 4 laptop and none seem suitable all have usb 2.0 and no parellel ports so another laptop seems to be in order probably a older model.....
Old 08-04-2008, 11:41 PM
jalessi's Avatar
jalessi is on a distinguished road
Smile
This might help if you really want to use a notebook.
See attached link
http://tinyurl.com/56ytrm
You would be much better off purchasing a full size P.C.
A notebook lacks video processing power.
Jeff...
Old 08-04-2008, 11:45 PM
jalessi's Avatar
Smile
You do not need to spend anywhere near $1,000.00 on steppers. drives power supply and BOB by the way.
Jeff...
Old 08-05-2008, 12:21 AM
I probably go with a full size pc. I have a couple I can steal from the kids and give them laptops. Anyway with that out of the way
Any Suggestions on the steppers and controllers? I prefer plug and play ready to run setup. If it involves soldering i perfer staying away from it. I can do it just perfer not to.
Old 08-05-2008, 12:46 AM
jalessi's Avatar
Smile
Take a look at the Gecko G540
http://www.geckodrive.com/product.aspx?c=3&i=14469
For $300.00 it has alot going for it, Mid-band resonance compensation
and 3.5 amp output is awesome.
For stepper motors KL23H286-20-8B :
http://www.kelinginc.net/NEMA23Motor.html
http://www.kelinginc.net/KL23H286-20-8B.pdf
For a power supply:
KL-350-48 48V/7.3A
http://www.kelinginc.net/SwitchingPowerSupply.html
C10 Bidirectional Breakout
Board :
http://www.kelinginc.net/c10.pdf
http://www.kelinginc.net/BreakoutBoards.html
I would suggest a different software package if you have the budget.
I have alot of pool cue inlay experiance by the way.
Jeff...
Old 08-05-2008, 01:04 AM
Thanks Jeff what oz servos do you recommend and what software do you recommend.
I been manual pantographing my inlays and its a pain I want this to be able to inlay cue butts and cutt v grooves for points in forearms. A bonus would be to throw a small taig lathe to spin a butt or shaft and have the cnc taper the profile.
I open to any and all suggestions you have.
Old 08-05-2008, 01:13 AM
jalessi's Avatar
Smile
The KL23H286-20-8B are 425 ounce and would be fine.
Have you decided on ball or acme screws?
Do you have a instant messenger?
My yahoo id: alchemist135
Jeff...
Old 08-05-2008, 08:01 AM
I will try to install yahoo messenger tonight.
Any how I already purchased Acme 1/2x10 screws with brass nuts in 48",24" and 12" I was going a different direction than a Modified Joes machine in 4x2 config originally. So I hope I can use the screw I have since I have them. I was on the fence about the brass nut I was told agter I ourchased I should of went delrin.
Old 08-05-2008, 10:46 AM
Another stupid question....
What is the purpose of a breakout board I was under the assumption the controller hooked dorect to your pc parallel port...
Also whats your thoughts on optical limit switches????
Old 08-05-2008, 11:09 AM
ger21's Avatar
What is the purpose of a breakout board I was under the assumption the controller hooked direct to your pc parallel port...
You use a breakout board when you use individual drives with each axis. Typically the 3 in 1 and 4in 1 boards do not need them. You also can use a breakout board to connect additional limit switches, relays, and other stuff. you can do this on a second port.
Dust will probably trip them, and you will have dust.
  #11   Ban this user!
Old 08-05-2008, 12:18 PM
jalessi's Avatar
Smile
If you purchase a all in one driver board like the Gecko you will not need a breakout board unless you add a mpg because the Gecko like most all in one boards has only four inputs and those will be used for your limit switches and possibly your Zero setting device.
You should get rid of the brass and get the Dumpster Anti-Backlash Leadnuts
http://www.dumpstercnc.com/leadnuts_acme.html
Do you have a name by the way?
Jeff...
  #12   Ban this user!
Old 08-05-2008, 12:32 PM
jalessi's Avatar
Smile
There are a few Zone users that have made enclosed optical limit switches
however most of the machines you see use a mechanical switch like this
http://tinyurl.com/5tkhpq
There are some very high end limit switches that are used on "big iron" however these work fine for what you will be doing.
Jeff...
Need Help!- Mach3 A axis (4th axis) setup? cadcamslawek Mach Software (ArtSoft software) 10 01-17-2012 09:23 PM
5-axis tool setup cdlenterprises General Metalwork Discussion 6 06-29-2009 01:48 AM
How do i setup my 4th axis on a maxnc? artur83 Safety Zone 0 04-15-2006 03:45 PM
Z axis setup MrBean DIY-CNC Router Table Machines 4 09-26-2004 12:55 PM
Z Axis Setup musicmkr DIY-CNC Router Table Machines 5 06-10-2004 12:33 AM
