Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 07-21-2008, 08:11 AM
thedoctor is on a distinguished road
Clock interupt or something?
Hi, all! I need to interrupt the program with a hard-contact input that does not require a keystroke to continue. I am using QuikStep4 on a INX Pentium2, Win 98. I have looked at a few other programs and none of the ones I have looked at have provisions for this, which I found a little weird. I just need to allow the torch height unit to go through its setup at the start of each cut and don't want to stand there hitting the "continue" button. Maybe a 12 volt solenoid on the mouse button? (yeah, right) Thanks!
Old 07-21-2008, 12:20 PM
Odin M Yggdrasi is on a distinguished road
Might be able to connect a relay across the mouse button to basically the same effect, once the mouse is positioned you then use a pulse generator to close the relay every half second or so to make the program continue.
What is this program waiting for other than user input? Trying to hard wire a contact like what you describe into a computer would be very involved, since not only would you have to make the actual physical device but would also have to modify portions of your operating system
Old 07-24-2008, 06:41 PM
Reason why
The stand-alone torch-height control I use has outputs for arc-established and pierce-delay. It needs to do its thing before the programmed cut begins. Both of my Burny units have this built-in but I am building this one from scratch.
Optical interupt switch implementation. owhite General Electronics Discussion 26 07-26-2009 05:27 PM
another clock balsaman WoodWorking 49 05-13-2009 09:17 PM
A cnc clock balsaman WoodWorking 69 01-26-2008 02:15 PM
Looking for CNC Plasma Clock dxf zeoncomp CNC Plasma and Waterjet Machines 1 01-09-2008 07:42 PM
Atomic Clock Al_The_Man CNCzone Club House 3 07-20-2006 03:15 PM
