Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 05-05-2008, 12:01 PM
Randy Stevenson is on a distinguished road
Strange Positioning Error - Anilam 1100
I'm out of ideas...
I've got a 3-axis Anilam 1100 setup on my Lagun mill. Everything works great except:
In the middle of running a program (either a built-in routine or a program loaded from disk), the x-axis will shift, sometimes +, sometimes -, half the tool diameter. No errors are reported and the program continues (at the new table position) until finished. Doesn't matter if toolcomp is on or off. When I first notice the cutter 'heading off', I stop and rapid to X-0, Y-0, and the cutter is always off of part x-0 (one way or the other) by half the tool dia.
It happens most often when taking a heaver cut. I can machine plastic OK, but switch to steel and the problem almost always surfaces. Have tried to load the servo by the handwheel on a practice run, but could not duplicate, so maybe it's vibration related?
Have cleaned and reseated any connecter or card related to the x-axis, and checked to make sure the encoder is not loose.
Has anyone run across this before?
Anilam 1100 postprocessor zrrigid Surfcam 1 04-18-2010 04:45 PM
Anilam 1100 Off line Software? dbur General CNC (Mill and Lathe) Control Software (NC) 4 05-07-2008 09:10 PM
Anilam 1100 english bob General CNC (Mill and Lathe) Control Software (NC) 2 02-08-2008 10:12 PM
1100 and 1400 anilam cpu need new where to get jetski Milltronics 0 11-27-2007 12:22 PM
anilam 1100 tmt_92021 General Metalwork Discussion 1 07-09-2006 12:28 PM
