Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 03-16-2008, 01:05 AM
jkblack is on a distinguished road
Problems FANUC OM and HYPERTERMINAL
Hi
I am new here, this is my first post
I am working on a vertical OM borer with a Fanuc controller, we are using Windows Hyperterminal to transfer files using a null modem cable to the RS232 port on the machine, this isn't a problem and works well.
The problem is when we need to send the program from Fanuc to PC, no matter what we try, we end up we a file that has the little square control character and then a extra line after every line of code. this means it has to be deleted by hand, what a pain.
Does anyone know how to set up Hyperterminal to fix this problem.
Peter
Old 03-16-2008, 02:14 PM
bborb is on a distinguished road
After starting and connecting with Hyperterminal, go to "File" "Properties", then click on the "Settings" tab next to "Connect to", and towards the bottom of the window click on "Ascii Setup", and make sure "Append line feeds to incoming line ends" is NOT checked.
Old 03-16-2008, 02:38 PM
FYI
http://www.kfasllc.com/rs232_0.htm
Old 04-11-2008, 09:19 AM
lethanhphuoc is on a distinguished road
first post
hi
Restarting after a stop DNC Drip Feeding via HyperTerminal is it possible? Rocko1 Haas Mills 3 09-12-2007 06:25 PM
Hyperterminal-Help mmachining Machine Problems, Solutions , Wireless DNC, serial port 6 03-23-2007 02:17 AM
Fanuc problems need help R.thayer Fanuc 3 01-27-2007 09:39 AM
Fanuc 3TC problems roni21702 Fanuc 3 03-15-2006 12:00 AM
Fanuc 3TC problems roni21702 Machine Problems, Solutions , Wireless DNC, serial port 5 03-11-2006 10:43 PM
