Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Controller & Computer Solutions
Controller & Computer Solutions Discuss computers and setups for cnc controllers.
Old 03-07-2008, 11:46 PM
bdphillips03 is on a distinguished road
Controller Retro Fit?
Hello. Hope this is the right forum.
I have an older small (8" swing) CNC lathe that uses encoders with servo drives. It also has a 8 station tool turret. It uses a Fanuc 6T style controller. BTW this was made by Rhino Robotics (ST/8) back in 1991.
My question. Is there a way to change and use a PC type driven controller? I emailed the nice folks at Mach and they said I would have to retro fit the lathe with steppers in order to use their software
Thanks for any advice.
Brian
Old 03-08-2008, 12:02 AM
MrWild is on a distinguished road
Sure. MESA Electronics. A 5i20 card for the control, a 7i33 board for the -+10v analog (unless the servo drives are PWM) and a 7i37 board for the ins and outs for spindle, Estop, etc ins and outs. If the drives are PWM, then skip the 7i33 and buy 2 of the 7i37s. You will need a PC of at least P3 at 1ghz, 512MN or RAM (1,024 is better), a 32mb vid card, and a copy of the latest EMC2.
All done for well under a grand. You just have to be smart enough to put it together.
Old 03-08-2008, 10:17 AM
Al_The_Man's Avatar
I imagine they indicated step/direction control which does not preclude servo's, just that you either need step direction servo drives or a converter from step/dir to analogue.
Also confirm your 6T does not have resolvers instead of encoders.
They also have a Galil card based system.
Old 03-08-2008, 02:09 PM
jeep534 is on a distinguished road
In the machsuport forums under show and tel there a number of people running retrofitted Hardinge cnc lathes as well as others. depending on the voltage and current requirements there are Various servo drives compatible with MACH3 as al the man said you must be sure that the encoders are are just that and not resolvers. also the price of steppers has come down so that may be an option as well however, I would recommend staying with the servo's both would require new drives.
Happy Hunting
archie =) =) =)
Brian
BP BTC II Retro DennisCNC Vertical Mill, Lathe Project Log 23 06-25-2008 08:49 PM
TM-5 for Retro in OKC mlogical HURCO 2 04-09-2008 01:09 PM
series 1 cnc retro? sdeering Bridgeport and Hardinge Mills 3 09-05-2006 11:29 PM
First part off the BP retro DennisCNC Bridgeport and Hardinge Mills 8 12-21-2005 08:21 PM
Help retro fit bp cnc arrowglide Bridgeport and Hardinge Mills 5 05-03-2005 09:36 PM
