| Controller & Computer Solutions Discuss computers and setups for cnc controllers. |
| I have a Cincinnati Arrow 500 VMC with a Acramatic 2100 (A2100) control Pentium 1 (75 mhz) with dual motherboards. I want to convert the PC portion to a modern Intel 775 CPU Motherboard. The Control is Windows NT based. I changed the Cmos batteries last week And suddenly the machine wont work. i did flash the bios on the rt board. I also reloaded the current software in the control from the hard drive This is a portin of the Siemens Email (they auqired the control from Vickers then stopped making it) A failure here usually means the WSCPU (1st motherboard) $2300 is at fault - it cannot communicate with the (2nd motherboard) RTCPU.. (My controll errors) The NC Engine Base test failed every time. Hardware Diagnostic Startup Status Bridge board (RI) #0 Results Unkown High Density I/0 #0 Results Unkown Pendant Panel #0 Results Unkown Read Time Processor #0 Results Unkown I think updating the motherboard to modern low cost parts would be a good investment. My machine uses Kollmorgen servos and servo amplifiers it has about 10 serial ports and two or three larger ports. I have been looking on the web and theres a lot of specialty pci serial port cards. Im not sure if there will be driver issues also. Anyone out there thats done something like this before? Thanks Mark |
| Hello there, I ve been playing with a vickers pc for the last 10 days so here is something you can try 1-take the RT MB off the machine 2-find an old ISA VGA card and push it in one of the slots 3-find an old power supply and attach it to where you give MB power 4-old keyboard or a converter so you can use the MB when you flashed the BIOS of the RT MB it back to default settings waiting for a floppy drive and a keyboard so get in the Bios and change the settings to 1-NO Floppy 2-Halt ON NO ERRORS that will make it go fine and the led on the right hand side on your bridge board should go off in a 5 secs during start wish that helps you mine was a little bit further problem |
| hi, i have a tree 250 with the acramatic 2100 and in desperately need the 2100 software. i have emailed siemens, and even tree repair shops and nobody has the software. do you have it saved where i could get a copy of it. i would be very greatfull.. thanks marc |
I have heard lots of discussion on replacing SABRE and Arrow products because of drive and control issues. I have also seen in these discussions that trying to replace these products with machines that can deliver the same capabilities is not inexpensive. Why not consider retrofit! I develop retrofit solutions for MAG products. MAG currently owns Cincinnati\G&L\FADAL and several other major Machine Tool Builder OEM's. I have had good success with retrofits. I currently have a kit available for Arrow's with the Control Techniques control and Sabre's with the Acramatic 850SX. I will be developing a A2100 replacement and a Kollmorgan drive replacement. There are planns to also supply control kits for the Cincinnati milacron Cinturn products. RV / themil |
| Hello there, I ve been playing with a vickers pc for one moth ago and I here is something you can try, and somebody help me??? I change the cmos battery's and lost the hard drive controler, i'm looking for a cmos program for reflashing the bios on the mother board... |
| Dear sir, I have recently bought an arrow 1000 machine. I tried powering it up. The control turns on, boots up normally, all tests passed. The message on lower left hand corner shows Machine off/Emergency stop PB. I started with checking the emergency stop switches they seemed to be correct. Drives seemed ok with 2 leds 1 red and 1 green . machine is off limits,. When I ran the extended diagnostics in continuous mode which showed the test failed , I have attached snap shots. I guess the person who tried to service the machine before me buying had changed the batteries in the RT board. Machine off/Emergency stop PB is unchanged even after pressing the power button many times. Nothing works on the machine. I have access to electronic card level service, but I do not know which part to service. I would request you to kindly advise me on the issue. Thank You Zubair |
Please give me a call in the office on Monday and I will be glad to help. MAG Global Services. MAG - The Global Machine Tool Manufacturer: MAG call 859-534-4748 |
| Acramatic 2100 | clayman | General Metalwork Discussion | 1 | 02-18-2011 06:29 PM |
| Networking the Acramatic A2100 | mwildin1 | General CNC (Mill and Lathe) Control Software (NC) | 6 | 01-21-2008 06:51 AM |
| GPOST postprocessor for Acramatic A2100 | beborracho | Post Processor Files | 0 | 08-08-2007 09:11 PM |
| Acramatic A2100 Benchman 5000 Prolight ATC | jwettroth | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-06-2006 02:02 AM |
| MasterCam V9.0 SP1 for Acramatic 2100 | Clawsie Machine | Post Processor Files | 5 | 09-03-2006 01:08 PM |
