Results 1 to 3 of 3
Thread: Software to Design path, not shape?
    Aug 2012
    Hi all,
    I about to start building my first CNC machine, and am a little confused about what software would be best for my case. The machine will hold a laser, and I want to be able to specify to path that the laser takes over time. For example, I might want to have the laser start in one corner, travel along the y-axis 20cm over the course of 15 seconds, and then upward along the z 10 cm in 10 seconds. I am not concerned with the overall shape of the path.
    It seems to me that most of the CNC software out there focuses on the end shape produced by the machine, not the path it takes. Would anyone we able to suggest a software package that would make the type of path design I'm trying to do easiest?
    Thanks so much in advance for any help you can offer me!!
    Tyler
    May 2004
    Won't your tool (laser) path ultimately make a shape? Start with learning how to write the code needed manually. You will be much better off in the long run.
    http://www.kirkcon.com/
    Aug 2012
    Yes, it will make a shape, but I don't want to instruct the laser the make a shape without concern for how it makes it. I want to specify the route it takes, not the end result.
  1. Replies: 0
    Last Post: 10-13-2011, 06:10 PM
  2. Replies: 0
    Last Post: 10-07-2011, 12:30 AM
  3. Need Help!- GravoStyle98 Software, How to fill a shape
    By keencoyote in forum Engraving Machines
    Last Post: 02-03-2011, 09:58 AM
  4. EZ-Path Desktop Software
    By md63825 in forum Bridgeport/Romi Lathes
    Last Post: 11-14-2010, 02:06 PM
  5. Finding Engineering Design Software For Automatic Machine Design
    By hellokitty in forum General CAM Discussion
    Last Post: 01-06-2008, 01:39 AM
