Results 1 to 11 of 11
Thread: USB to RS232 converter cables?
    Jan 2012
    Has any one had any luck using converter cables for DNC with their cnc machines? I am using Bobcad V24 with predator cnc editor 2005 for bobcad. My computer does not have any serial ports just usb. I have changed all the port settings to match my cnc settings and can get the predator editor to upload the code but my cnc machine is not receiving it. Thanks
    Feb 2012
    England
    So the program you're using recognises USB?
    Jan 2012
    It seemed to at one point because the p. editor processed the upload on my pc but got nothing on the cnc controller end?
    Feb 2012
    England
    With the release of Windows XP and computer manufactures only installing USB ports, users are finding that a USB to serial adapter is the only solution they have to try to communicate to their CNC machine. The truth be known, many off-the-shelf manufacturers of USB to serial adapters are not 100% compatible and communication to the CNC machine is unreliable, slow, or only limited to one way transmission.
    Feb 2012
    England
    May 2008
    I have had similiar problems. You may need a "null Modem adaptor"
    Jan 2006
    I have had great luck with anything built on an FTDI chip. You can buy a converter directly from them or from someone like Digikey.
    USB-COM232-PLUS1 FTDI, Future Technology Devices International Ltd | 768-1032-ND | DigiKey
    B&B Electronics also sells professional stuff and they have top notch support.
    Industrial Communication Solutions - B&B Electronics
    Good luck
    Matt
    May 2006
    i recently bought one from cablestogo it is called usb to db9. less than $30 with driver disk. it installed on com6 i was able to change it to com1 easy.
    Registered TonyW's Avatar
    Jan 2011
    Serial Server
    I'm using a B&B Electronics VLinx serial server for my NC machines. I have the serial server in the electrical enclosure on machine, which plugs into Ethernet. The PC is also plugged into Ethernet. The software that came with the serial server creates a 'virtual' serial com port on PC. Once connected with the right cable from serial server to cnc serial port, everything works well and quite quickly. I think I paid $200 for the serial server.
    Feb 2009
    Been using one for the last 7+ years. Think mine was Atec or something like that.
    Jul 2004
    Most of the off-the-shelf USB to Serial adapters seem to work great under Windows XP and are low cost. We spent 2 yrs looking for the right solution and then worked with the mfg to understand how to make them work with CNCs. Updating the drivers to support baud rates like 1200, 2400 and even 4800 were a challenge for them. They always asked, why does a CNC run so slow...well we all want them to run at 115K but most run at 9600 or slower.
    With that said, we put it to the test and connected to over 50+ types of controls and documented, created our own setup docs for machines and Windows 7. We even did one better and tested with many DNC products like Bobcad, MasterCAM, eXtremeDNC and Predator.
    Most of the other mfgs just port the drivers from XP to Windows 7 and hope they work for 32 /64 bit code. It just does not work, again for our applications. If we are talking GPS and PLCs, not generally a problem.
    Give us a call, we can probably help with BOBCAD problem since we also sell Predator.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
    1. Need Help!- USB to RS232 converter cables
      By shoptalk00 in forum BobCad-Cam
      Last Post: 03-26-2012, 08:22 PM
    2. USB Memory stick to RS232 converter
      By hrh in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 04-24-2011, 08:59 AM
    3. Need Help!- cables
      By MR MOTION in forum BobCad-Cam
      Last Post: 07-28-2009, 12:33 AM
    4. Hurco KM1 RS232 to USB OR RS232 to PCMCIA solution?
      By modernprecision in forum Bridgeport and Hardinge Mills
      Last Post: 09-11-2008, 02:15 PM
    5. RS232 cables
      By SIG in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 12-11-2007, 11:52 PM
