Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: Galil DMC-1050 controller retrofit
  1. #13
    Dec 2003
    Unfortunately this software only runs under DOS and the DMC-1000 ISA bus,
    I have some of these systems still working after 20yrs.
    The problem in the future maybe getting ISA PC's.
    I tended to buy Advantech single board PCI PC/s and use a combo Back plane.
    No problem with Galil drivers.
    Feb 2012
    Usa
    The upgrade went very well. The adapters are reasonably priced and Galil shipped quickly. I initially thought the adapters would plug into the cards and my old DMC-1050 cables would plug into the adapters. However, this is not the case. I still needed the newer cables (cable-100-m) intended for the DMC-1880. Hardware route is as follows; DMC-1880 -> Cable-100-M -> CB-1500-10 -> Older 60 pin cables -> ICM-1100.
    The machine was already wired to the ICM-1100's, going this route allowed me to upgrade to a PCI board, Newer computer, Operating System (WinXP), and Mach3 with Galil plugin using G-code without manual conversion, without rewiring. If I could have found the ICM-1900's for a good price adapters would not be need but rewiring would.
    The plugin works well so far far; my only issues with it were configuration.
    1 Description of Limits in plugin config appear to be backwards from the Galil command set.
    2 I was not able to jog off of a limit until I entered ports and pins in the jog entries in setup. (the manual did not mention entering anything for Jog)
    Although I achieved the initial objective of using Mach3 with Galil, through the process I got the opportunity to learn a good amount of the Galil command set. I have to say I really like it. It is intuitive and organized. I wish there was an affordable front end (GUI) that takes the place of Mach3. It would be a bit cleaner in implementation and operation. As I understand, Camsoft is it but nowhere affordable in my opinion.
  3. #15
    Dec 2003
    Quote Originally Posted by Jmhx2 View Post
    That has long been a beef of mine, Galil did make an effort to come up with a GUI as per the software I mentioned in above post, but it was dropped with the advent of the PCI cards and Windows.
    This was the reason at that time I switched to Acroloop which not only had a front end but also had built in PLC's.
    I am still running a couple of machines with them.
    Then Parker took them over and that was the end.
    May 2005
    Quote Originally Posted by Al_The_Man View Post
    Make that two.
    I am using a Galil ethernet controller for a "pick and place" type project and am very impressed, would love to use it on my Boss6 bridgeport retrofit.
  1. Replies: 9
    Last Post: 12-11-2012, 07:19 AM
  2. GE 1050 controller on Behrens Turret Punch
    By TZak in forum General Metal Working Machines
    Last Post: 12-09-2010, 10:53 PM
  3. Fanuc to Galil to Mach3 retrofit
    By cnctech101 in forum Mach Mill
    Last Post: 09-30-2009, 08:46 AM
  4. Need help:galil controller: DMC1341-manual
    By radusa in forum Controller Cards
    Last Post: 07-30-2009, 06:41 PM
  5. Need Help!- 1050 GE Controller
    By clindsay in forum General Electronics Discussion
    Last Post: 10-20-2008, 12:28 AM
