| Controller & Computer Solutions Discuss computers and setups for cnc controllers. |
Hey Everyone I've been trying to figure this out for a couple days now...and Fagor's solution is to send *edit* the CNC Central Unit* in so that they can take a look at it. Unfortunately I don't really have time to send it there and was wondering if anyone has ever had the same problem? One of the operators of the Quintax - Fagor 8070 was jogging the machine around and it just stopped. An error came on the screen: Error 4000 Error when initializing the sercos ring Logic Axis: Transition: 127 (this number changes...) Transition: 32 (this number changes...) Wrong Value: 1 (this number changes...) Wrong Value: 513 (this number changes...) ID: 321-367 So that was the initial error. I tried restarting it a few times and all that did was give me more and more errors. Error 6016 CAN error counter at critical level ID 325-557 Error 6007 Watchdog in the COMPCI Wrong value: -7 ID: 325-207 Error 6012 CAN Controller error Wrong value: 324 ID: 325-536 Error 5014 Wrror when writing the digital outputs of the PLC Variable: ID: 501-1571 Error 6006 Watchdog: one or several CAN nodes do not respond Wrong value: -4 ID: 325-180 Error 6020 CAN cycle overlap ID: 325-480 Now I was thinking that the CAN Bus (which I really do not know anything about) is either not sending the correct signals or is not receiving the correct signals. All of the Servo Drives had a small "0" on them. I followed the purple cable from the "CNC Central Unit" that has a Brown, White, and Black wire in it, back to the electrical cabinet. This was the wire from the CAN Bus according to Burt at Quintax. We tested all the wires to make sure the connection was good to the I/O box and everything checked out. We powered up the CNC again (the machine had been off for probably an hour) and what do you know...It works. Now I thought it was a wire had just rattled loose (which our maint. dept thought was impossible) and I closed everything up and the operator went back to trimming. About half an hour later, or less, the machine froze up again and had the same problem. Coming up with Error 4000 and all of the CAN problems. I'm thinking it is the CAN Bus now since all of the drives are showing the same. I'm pretty sure the power supply is not the problem, but it IS flashing a Fault. If it is the power supply (that one beside all of the servo drives), we have a different spare power supply from a Quintax/Fagor 8055. I'm not sure if they're compatible even though they have the same part number: PS-25-B4 The difference is the 8070 has: LSC: 31A CTRL: 03A VAR: 21A 8055 has: LSC: 34A CTRL: 07A VAR: 21A That's another option. This morning, after being off the whole night, the operator tried running it again (before I got to work) and he got about 8 cycles out of the machine before it locked up again. ......So.....should I order a new "CNC Central Unit" (8070-VC-PC104-A) or is there something else we can try? Thanks for any help in advance Last edited by AcryNom; 02-01-2012 at 10:12 AM. Reason: Update |
| What we ended up doing was replacing the CNC Central Unit. Pretty easy to take out of there and replace. We never sent the old Unit in to get checked out and repaired. When we do I'll ask them what the problem was and post the answer. Thanks for your response |
| Need Help!- Quintax with Fagor 8055 | molson | Commercial CNC Wood Routers | 3 | 11-29-2011 09:49 AM |
| Need Help!- 5 AXIS Fagor 8070 post for MasterCam X4 | mberdan | Post Processor Files | 1 | 05-23-2010 01:10 PM |
| Fagor 8070 Mastercam post | Camero | Fagor Automation | 0 | 05-14-2010 03:46 PM |
| Why are both tables moving? Problems with Fagor 8070 | AcryNom | General CNC (Mill and Lathe) Control Software (NC) | 1 | 11-13-2008 04:43 PM |
| I am having problems with my OTM Ring Groove Cutting Tool...Please help. | Nick K | CNC Tooling | 0 | 07-20-2008 09:40 PM |
