It sounds like a mechanical problem. There might be a gall on the slide - the MaxNC uses aluminum-to-aluminum slides with just a thin layer of decorative anodizing between. Once that's gone, it's pretty easy to raise a spot that impedes smooth motion. There could also be a lubrication failure, or an issue with your plastic nuts, the gibs might need adjustment or the 1/4" leadscrew could be bent. Take note of where the error occurs and which axis is faulting, then disassemble the offending axis and check it out.
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
LinkBack URL
About LinkBacks
